error in changing Assy Patt elements BOM struc to Ref
brianA32ZM
Message 1 of 1
brianA32ZM
Hello, somehow I lost the ability to change (manually or with ilogic) an individual assembly pattern element component's bom structure in an existing assembly. Instead of just changing the BOM structure of item 1 in element 2 the bom structure is of item 1 is changed in all the elements. Currently working in 2023; is there a setting that would have changed this behavior?
update: The culprit appears to be Model States. If more than one Model State exist, then I can no longer change the bom structure on individual elements components.
Replies (0)
