Error in Apprentice
Error in Apprentice
abilabib
Error in Apprentice
abilabib
I've some file where's can't save in Apprentice mode.
Here's the alert.
An unhandled exception of type 'System.UnauthorizedAccessException' occurred in mscorlib.dll
Additional information: Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
Could some one tell me how to solve this problem.
chandra.shekar.g
Autodesk Support
Autodesk Support
@abilabib,
Saving of files in Apprentice is not allowed on files that require migration (any file that has not already been migrated to the same version of the Apprentice server). The current document's NeedsMigrating property must return False before the FileSaveAs object can successfully be returned. Otherwise, same exception is thrown as you mentioned in earlier post.
Can you please provide sample file to test? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
abilabib
@chandra.shekar.g : Many thanks for your reply. You're correct. The file is use 2011 and I wanna save as to 2015 using apprentice. I'm understand now.
Afri
Could you please share your codes for reference? I also encounter the same issue. Thank you.
