Creating apprentice application - Inventor not installed
Jef_E
Message 1 of 12
Jef_E
Hi there,
I have been challenged to create a simple application for editing some specific iProperties. I made this application on my Desktop and everything runs smooth. Now I would like to run the application on a desktop that does not have Inventor installed.
From the research I did, it seemed possible, but now I am not so sure as I am getting a error on this sub.
Public Sub New()
    ' This call is required by the designer.
    InitializeComponent()
    ' Setup a new apprentice server component
    ApprenticeServer = New ApprenticeServerComponent
End Sub
Well thats a bummer. Are there specific requirements for running apprentice on a desktop that don't have Iventor Installed?
I do have Inventor view 2019 Installed and the source was written on a 2014 Interop version.
Quote:
Another feature of Apprentice is the cost. Apprentice is freely available and is distributed as part...
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (11)
Message 2 of 12
bradeneuropeArthur
You need inventorview this is freeware. Than apprentice is installed too
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
Jef_E
I have Inventor view installed but it's version 2019. My Addin interop version is 2014. Could this be the problem?
Inventor 2014 SP2
Message 4 of 12
bradeneuropeArthur
Why don't you copy the Autodesk interop dll with your application?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
Jef_E
Same error,
System.Runtime.InteropServices.COMException
  HResult=0x80040154
  Message=Retrieving the COM class factory for component with CLSID {C343ED84-A129-11D3-B799-0060B0F159EF} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
  Source=EllimetalXpress
  StackTrace:
   at EllimetalXpress.Xpress..ctor() in T:\ALGEMEEN\jeee\xpress\EllimetalXpress\Xpress.vb:line 29
Inventor 2014 SP2
Message 6 of 12
bradeneuropeArthur
try to compile your application with framework 4.7, since this is needed for inventor 2019.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
Jef_E
Still the same error.
Inventor 2014 SP2
Message 8 of 12
bradeneuropeArthur
could you provide the code..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
Jef_E
Imports Inventor
Public Class Xpress
    Private m_apprentice As ApprenticeServerComponent
    Public Sub New()
        m_apprentice = New ApprenticeServerComponent
    End Sub
End Class
Red line is the error line...
Inventor 2014 SP2
Message 10 of 12
bradeneuropeArthur
Have you really installed "https://www.autodesk.com/viewers/all-viewers"
http://usa.autodesk.com/adsk/servlet/pc/index?id=10535296&siteID=123112
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
Jef_E
Yes I have! even deleted it and installed it again. Will try at home I am sensing some permission issues..
Inventor 2014 SP2
Message 12 of 12
HideoYamada
