Error Handling if printer not found
karthur1
Mentor Mentor
1,065件の閲覧回数
11件の返信
メッセージ1/12
karthur1
I have made a "one-click print" iLogic rule to make printing simplier.  I would like to add some error handling if it is not able to find the printer.   The printer name is hard-coded in the iLogic. The way it is now, I get the error below.
Is there a way to catch this and just display a message that makes it obvious to the user as to what is wrong?
0 件のいいね
解決済み
1,066件の閲覧回数
11件の返信
返信 (11)
メッセージ2/12
Andrii_Humeniuk
Hi @karthur1 . In your rule, the document is specified as a drawing:
Dim oDrgDoc As DrawingDocument
oDrgDoc = ThisApplication.ActiveDocument
Based on your error, you are trying to run a rule in an assembly (871319.iam):
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
0 件のいいね
メッセージ3/12
karthur1
Not what I originally meant, but can we catch that situation too?
 Below is the message I get when I run it on an IDW.  I know the problem is because the printer name in my code is not the same as the system printer (IT changed the name on me).
0 件のいいね
メッセージ4/12
Andrii_Humeniuk
Is the Try-Catch method right for you?
Try
	oDrgPrintMgr.Printer = "\\SRV-VM-RUS-DC2\FMI Engineering - BW Ricoh MP C4504EX PCL6"
Catch
	MessageBox.Show("Printer not found - FMI Engineering - BW Ricoh MP C4504EX PCL6",
					"Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Exit Sub
End Try
メッセージ5/12
karthur1
Yes, That works for me.
How do I test to make sure that it is being ran on an IDW document?  I tried this, but it doesn't work.
0 件のいいね
メッセージ6/12
Andrii_Humeniuk
Please try this code:
If System.IO.Path.GetExtension(oDrgDoc.FullDocumentName) = ".idw" Then
End If
Or:
If oDrgDoc.IsInventorDWG = False Then
End If
0 件のいいね
メッセージ7/12
karthur1
 It gets by the error check it when I run it on a IDW, but when I run it on a IAM, it fails on line 2.
If System.IO.Path.GetExtension(oDrgDoc.FullDocumentName) <> ".idw" Then
	MessageBox.Show("Please run this rule from an IDW file.", "iLogic")
		Exit Sub
End If
I get this error when I run it on an IAM.  It never gets to the IF statement.
0 件のいいね
メッセージ8/12
Andrii_Humeniuk
解決済み
If I were writing this rule, I would do it like this:
Dim oInvApp As Inventor.Application = ThisApplication
Dim oDoc As Document = oInvApp.ActiveDocument
If Not TypeOf oDoc Is DrawingDocument Then
	MessageBox.Show("Active document is not drawing!",
	Exit Sub
End If
Dim oDrgDoc As DrawingDocument = oDoc
	MessageBox.Show("Active drawing is not .idw!",
	Exit Sub
End If
' Set reference to drawing print manager' DrawingPrintManager has more options than PrintManager' as it's specific to drawing document
Dim oPrintMgr As DrawingPrintManager
oPrintMgr = oInvApp.ActiveDocument.PrintManager
'Set the printer name. Either Change this to match the system printer name, or change the system printer to this name
'(comment this line to use Default printer Or assign another one).
Try
Catch
	Exit Sub
End Try
'Set Color Mode
oPrintMgr.ColorMode = kPrintGrayScale
'oPrintMgr.ColorMode = kPrintColorPalette
'Set Orientation
'oPrintMgr.Orientation = kPortraitOrientation
oPrintMgr.Orientation = kLandscapeOrientation
'Set Paper Size. Height x Width units are in centimeters.
oPrintMgr.PaperSize = kPaperSize11x17
'oPrintMgr.PaperHeight = 17
'oPrintMgr.PaperWidth = 11
oPrintMgr.ScaleMode = kPrintBestFitScale
' Set to print all sheets.
	oPrintMgr.PrintRange = kPrintAllSheets
'	oPrintMgr.PrintRange = kPrintCurrentSheet
oPrintMgr.SubmitPrint
0 件のいいね
メッセージ9/12
Frederick_Law
解決済み
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-DF62A491-8743-492B-B2FB-BBF30C77B34E
oDoc = ThisDoc.Document
If oDoc.DocumentType = kDrawingDocumentObject Then
'Do Printing here
End if
メッセージ10/12
WCrihfield
Basically, any time a rule is for a specific type of document, and it is possible for that rule to be ran on any other type of document, you should always check the Type of document you are getting a reference to, before trying to set that document reference to any of the 'specific' document Type variables (AssemblyDocument, DrawingDocument, PartDocument).  If you try to check document type afterwards, the error will have usually already happened.  If you try to set an AssemblyDocument as the value of a DrawingDocument type variable, it will throw an error.  There are several popular ways to deal with that situation, depending on the situation, and your individual coding style.
Below are a few starting lines examples I often use:
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
	Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisDoc.Document
or
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
or
If Not TypeOf ThisDoc.Document Is AssemblyDocument Then Exit Sub
There are lots of other similar examples too.  Whichever suits your needs & style best.
Wesley Crihfield
(Not an Autodesk Employee)
メッセージ11/12
karthur1
I got it to work!!!  Changed these lines to this.  It works for either IDW or DWG format.
Many Thanks
0 件のいいね
メッセージ12/12
Frederick_Law
I don't like "exit sub", "goto".
Structured Programming.
I'll use:
'Do Printing here
else
End if
0 件のいいね
