Error Getting parameters
Hi everyone,
I have a snippet of code I am using to open a template file and modify the parameters of the template. I usually then save the part under a new name and place it into an assembly
Here is the snippet:
SyntaxEditor Code Snippet
'Template Path
TemPath= "K:\TKSY WASHER TEMPLATE.ipt"
'Open Template
ThisApplication.Documents.Open(TemPath)
Dim oDocument As inventor._Document = ThisApplication.documents.itembyname(TemPath)
'Modify Template
Dim Testprop As String
Dim oParameters As Parameters
Dim oChangeParam As Parameter
oParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
Check=ThisApplication.ActiveEditDocument.FullFileName
MessageBox.Show(Check)
'MsgBox("Here")
oChangeParam = oParameters.Item("OD")
oChangeParam.Expression = 100
This works fine on it's own or in some other rules.
I am making a new rule to place a custom washer. This rule replaces an existing rule which was a little messy (needing an input box for each parameter). The new rule creates user parameters in an assembly, shows a form for the user to change the parameters, opens the template file, uses the parameters inputted to the form to modify the washer, inserts the washer into the assembly and deletes the user parameters.
However, when I use the snippet of code above in my new rule I get an error. I think it is *something* to do with the "Material" parameter. Can anyone see my mistake(s)? Thanks in advance.
Sub Main
'Washer Rule 2'Dim oDoc As AssemblyDocument=ThisDoc.Document
oDoc = ThisDoc.Document
Dim PartNum as String
Dim MFCode As Single
Dim NewPath As String = "K:\WASHERS\"
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByExpression("OD", "10", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter=oMyParameter.AddByExpression("ID", "5", "mm")
oParameter=oMyParameter.AddByExpression("Thickness", "8", "mm")
oParameter=oMyParameter.AddByExpression("CHAMFER", "1", "mm")
oParameter=oMyParameter.AddByValue("Material", "070M20 (EN3B)", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("Finish", "Blacken", UnitsTypeEnum.kTextUnits)
MultiValue.SetList("Material", "070M20 (EN3B)", "080M15 (EN32)", "BO1")
'iLogicForm.Show("Place Washer Form", FormMode.NonModal)
iLogicForm.Show("Place Washer Form", FormMode.Modal)
'MsgBox(Parameter("Material"))
Select Case Parameter("Material")
    Case "070M20 (EN3B)"
        MultiValue.SetList("Finish", "BLACKEN", "PROTECT WITH LIGHT OIL", "TUFFTRIDE 60±2 HRC", "ZINC PLATE AND YELLOW PASSIVATE FE/ZN8", "NATURAL")
        Dim ListString As ArrayList  = MultiValue.List("Finish")
        Parameter("Finish") = InputListBox("Select Finish", ListString, "", "TKSY Standard Washer", "Available Finishes")
    Case "080M15 (EN32)"
        MultiValue.SetList("Finish", "CASE HARDEN 60±2 HRC CASE 0.5 DEEP")
    Case "BO1"
        MultiValue.SetList("Finish", "HARDEN & TEMPER 60±2 HRC")
End Select
'Make Part Number'Material and Finish Code
If Parameter("Material") = "070M20 (EN3B)" And Parameter("Finish") = "BLACKEN" Then MFCode=1
If Parameter("Material") = "070M20 (EN3B)" And Parameter("Finish") = "PROTECT WITH LIGHT OIL" Then MFCode=4
If Parameter("Material") = "070M20 (EN3B)" And Parameter("Finish") = "TUFFTRIDE 60±2 HRC" Then MFCode=5
If Parameter("Material")= "070M20 (EN3B)" And Parameter("Finish") = "ZINC PLATE AND YELLOW PASSIVATE FE/ZN8" Then MFCode=6
If Parameter("Material") = "080M15 (EN32)" Then MFCode = 2
If Parameter("Material") = "BO1" Then MFCode = 3
'FInal Part Number
PartNum = "PS-" & Parameter("OD") & "-" & Parameter("ID") & "-" & Parameter("Thickness") & "-" & MFCode
'Check Result'MessageBox.Show(PartNum)
'Set the Chamfer size based on Washer OD'MsgBox(Parameter("OD"))
Select Case Parameter("OD")
    Case <6
        Parameter("CHAMFER") = 0.3
    Case 6 To 16
        Parameter("CHAMFER") = 0.5
    Case 16 To 50
        Parameter("CHAMFER") = 1
    Case >50
        Parameter("CHAMFER") = 1.5
End Select
'MsgBox(Parameter("CHAMFER"))
MsgBox(NewPath & PartNum & ".ipt")
'Open Exhisting Washer
If System.IO.File.Exists(NewPath & PartNum & ".ipt") Then
    ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, PartNum & ".ipt")
    ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute()
    ThisApplication.ActiveDocument.Update2(-1)
 Else
    'MessageBox.Show("Not found, yo!")
    NewWasher
End If
'Delete Parameters
Dim param As Parameter
Try
    param=oDoc.ComponentDefinition.Parameters.Item("OD")
    param.Delete
    param=oDoc.ComponentDefinition.Parameters.Item("ID")
    param.Delete
    param=oDoc.ComponentDefinition.Parameters.Item("Thickness")
    param.Delete
    param=oDoc.ComponentDefinition.Parameters.Item("CHAMFER")
    param.Delete
    param=oDoc.ComponentDefinition.Parameters.Item("Material")
    param.Delete
    param=oDoc.ComponentDefinition.Parameters.Item("Finish")
    param.Delete
    Catch
        MsgBox("Parameters not found!")
End Try
End Sub
Sub NewWasher
'Template Path
'Open Template
'Modify Template
MsgBox("Here")
End Sub
I decided to make the rule in a different way; I place the template part in the assembly and then modify/save and replace. Whilst this works I'd still be interested to know if anyone has any ideas on my original error.
