Equation Curve - Error - Square-root of zero or negative number
coltong
coltong
What I'm trying to do
I'm trying draw a an equation curve:
  • File type:  .ipt
  • Equation Type: Explicit, Cartesian
  • Desired range: xmin = 0 to xmax = 2.63
  • Equation:  11.75 in * PI * ( 0.32914 ul - ( 0.0290921 ul * sqrt(128 ul - ( 48.611533 ul * x ))))
The Problem
Inventor will plot the equation from xmin = 0 to xmax =1.035 (see Image 1), but any value greater than 1.036 will output this error  "cannot evaluate square root or a negative number" (see Image 2).   The "128 ul - ( 48.611533 ul * x )" argument of the sqrt function is not negative over the range of xmin = 0 to xmax = 2.63.
What the heck is going on?  I have attached an .ipt file with the equation curve.
Image 1:  Plot works from xmin = 0 to xmax = 1.036
Image 2:  Plot error for xmin=0 to xmax=1.04
Thanks for you help! 😄
TomaszDąbrowski
My opinion - this is a problem with units.
I will focus on this piece of exuation, because it must be positive:
You mentioned that it works with x=1,036, so I asume that it doesn't work with x=1,037.
128-(48,611533*1,037) = 77,5898 - looks fine, but
128-(48,611533*1,037*2,54) = -0,04180 - is negative, let's check for 1,036
128-(48,611533*1,036*2,54) = 0,08167 - is positive
So when I multiply x by 2,54 (in-cm transformation) I get the results you described.
Coincidence? I don't this so 😉
