I have started getting this error in Inventor 2025.
I believe this one is due to the change to .Net Core from framework.
"System.NotSupportedException: No data is available for encoding 1252. For information on defining a custom encoding, see the documentation for the Encoding.RegisterProvider method.
at Microsoft.VisualBasic.Strings.StrConv(String str, VbStrConv Conversion, Int32 LocaleID)
at ThisRule.Main() in rule: iProperties, in document FRAME WELDMENT_FERO_4-LEG.ipt:line 18
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at Autodesk.iLogic.Exec.AppDomExec.ExecCodeHere()
at Autodesk.iLogic.Exec.AppDomExec.ExecCodeInOtherDomain(AppDomain otherDomain, String assemName)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
No data is available for encoding 1252. For information on defining a custom encoding, see the documentation for the Encoding.RegisterProvider method."
The offending line is:
StrConv(Classification,VbStrConv.ProperCase)
How can I add this encoding method?
