Encoding Error - No data is available for encoding 1252
william
william
I have started getting this error in Inventor 2025.
I believe this one is due to the change to .Net Core from framework.
"System.NotSupportedException: No data is available for encoding 1252. For information on defining a custom encoding, see the documentation for the Encoding.RegisterProvider method.
at Microsoft.VisualBasic.Strings.StrConv(String str, VbStrConv Conversion, Int32 LocaleID)
at ThisRule.Main() in rule: iProperties, in document FRAME WELDMENT_FERO_4-LEG.ipt:line 18
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at Autodesk.iLogic.Exec.AppDomExec.ExecCodeHere()
at Autodesk.iLogic.Exec.AppDomExec.ExecCodeInOtherDomain(AppDomain otherDomain, String assemName)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
No data is available for encoding 1252. For information on defining a custom encoding, see the documentation for the Encoding.RegisterProvider method."
The offending line is:
StrConv(Classification,VbStrConv.ProperCase)
How can I add this encoding method?
Curtis_Waguespack
@william , I've known a couple of people seeing this error with add-ins that worked fine in 2024 or earlier, but throw this error in 2025.  I have not seen Autodesk give any information about how to address it though.
Your error appears to be from an iLogic rule and not an add-in. Can you confirm that this is/is not the case ?
@MjDeck , @johnsonshiue
william
Thats correct. Just an iLogic rule.
All I am trying to do is format an inventor text parameter to proper case.
It has worked fine in previous versions.
MjDeck
This is caused by the move from .NET Framework 4.8 to .NET 8 in Inventor 2025.
To get the rule to work in Inventor 2025, add this at the top:
AddReference "System.Text.Encoding.CodePages"
Imports System.Text
Encoding.RegisterProvider(CodePagesEncodingProvider.Instance)
@Curtis_Waguespack , similar code will also work in an add-in.
(For this particular function, there is also a newer method  TextInfo.ToTitleCase. But that will not convert a string that is ALL CAPS.)
Mike Deck
Software Developer
Autodesk, Inc.
william
Champion! Works nicely.
