Ellipse End Point As Dxf File
isocam
isocam
Can anybody help?
I am trying to get the start and end point of an elliptical arc to be the same as an AutoCAD dxf file.
I am using the following code.....
 Case kSketchEllipseObject, kSketchEllipticalArcObject
                    CentreX = sketchEnt.CenterSketchPoint.Geometry.x * 10
                    CentreY = sketchEnt.CenterSketchPoint.Geometry.y * 10
                    X1 = sketchEnt.MajorAxisVector.x * 10
                    Y1 = sketchEnt.MajorAxisVector.y * 10
                    MajorRadius = sketchEnt.MajorRadius * 10
                    MinorRadius = sketchEnt.MinorRadius * 10
                    AxisRatio = MinorRadius / MajorRadius
                    EllipseAngle = Atn(Y1 / X1) * Rad
                    X1 = 0 - (MajorRadius * Cos(EllipseAngle * Pi / 180))
                    Y1 = 0 - (MajorRadius * Sin(EllipseAngle * Pi / 180))
                    Select Case sketchEnt.Type
                           aStart = 0
                           aEnd = 2 * Pi
                      Case kSketchEllipticalArcObject
                           Angle = sketchEnt.StartAngle
                           aStart = Atn(Sin(Angle) / (AxisRatio * Cos(Angle)))
                           If aStart > (Angle + Pi) Then aStart = aStart - (2 * Pi)
                           If aStart < (Angle - Pi) Then aStart = aStart + (2 * Pi)
                           Angle = Angle + sketchEnt.SweepAngle
                           aEnd = Atn(Sin(Angle) / (AxisRatio * Cos(Angle)))
                           If aEnd > (Angle + Pi) Then aEnd = aEnd - (2 * Pi)
                           If aEnd < (Angle - Pi) Then aEnd = aEnd + (2 * Pi)
                    End Select
I can get the start point OK but I am having problems with the end point.
Does anybody know what I am doing wrong?
Vladimir.Ananyev
The following VBA sample illustrates access to end points of the sketch elliptical arc:
Sub SketchEllipticalArc_Ends()
  Dim oSketch As PlanarSketch
  Set oSketch = ThisApplication.ActiveEditObject
  Dim oArc As SketchEllipticalArc
  Set oArc = oSketch.SketchEllipticalArcs.Item(1)
  Dim StartPoint As SketchPoint
  Set StartPoint = oArc.StartSketchPoint
  Dim EndPoint As SketchPoint
  Set EndPoint = oArc.EndSketchPoint
  With StartPoint.Geometry
    Debug.Print "Start point  x = "; .X
    Debug.Print "Start point  y = "; .Y
  End With
  With EndPoint.Geometry
    Debug.Print "End point    x = "; .X
    Debug.Print "End point    y = "; .Y
  End With
End Sub
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
