Editing published iparts
AMN3161
AMN3161
Ok i had a ipart that i already published into the content center library, how do i go back and edit the model? not all the published data but the ipart model its self
cbenner
The original model should still be wherever you had it saved before you published it.  If you change the ipart, it will not change the published CC part.  Unless you use Replace Template in CC.
