Edit sketch symbol value
Hello!
I have currently started to use sketch symbols with my Inventor drawings. In some cases, the text in some symbols is needed to be changed. In the past, I have seen, that it can be done more easier, then editing the whole symbol in the sketch mode. Can anybody, more fluent to the issue, lead me to the right solution by explaining me how it can be done?
Just in case, I uploaded an example of my issue in here.
With best regards
Raul
HideoYamada
Hello Raul,
You can insert Model / Drawing properties into the Text.
See this video.
https://autode.sk/2mINt9E
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Thank you for the reply.
This is one way to approach to the problem, but is there maybe some other solution?
From the past I remember that sketch symbol value edit was possible inside the ''Edit field text'' window. Some ideas about that?
HideoYamada
To edit the texts in the dialog, you should insert Prompted Entry Field.
https://autode.sk/2mLshQc
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
YES!
That was the trick 🙂
Thank you!
