Hi Georg,
This could be a way to find the last OrdinateDimension in the set:
Function GetLastDimensionInSet(ByVal ordDimSet As OrdinateDimensionSet) As OrdinateDimension
Dim ordDim As OrdinateDimension
Dim max As Double
For Each ordDim In ordDimSet.Members
If ordDim.ModelValue > max Then
max = ordDim.ModelValue
Set GetLastDimensionInSet = ordDim
End If
Next
End Function
In order to get more information about the selection you could subscribe to the OnSelect event of UserInputEvents. This way you could get the model position of the selection which would help you identify the selected dimension:
Function GetClosestDimensionInSet(ByVal ordDimSet As OrdinateDimensionSet, ByVal pt As Point2d) As OrdinateDimension
Dim tr As TransientGeometry
Set tr = ThisApplication.TransientGeometry
Dim min As Double
min = 1000000
Dim poly As Polyline2d
Set poly = ordDim.DimensionLine
Dim i As Integer
For i = 1 To poly.PointCount - 1
Dim line As LineSegment2d
Set line = tr.CreateLineSegment2d(poly.PointAtIndex(i), poly.PointAtIndex(i + 1))
If line.DistanceTo(pt) < min Then
min = line.DistanceTo(pt)
Set GetClosestDimensionInSet = ordDim
End If
Next
Next
End Function
Inside OnSelect you could use it like this:
Private Sub uiEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, MoreSelectedEntities As ObjectCollection, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
Set ordDim = GetClosestDimensionInSet(JustSelectedEntities(1).OrdinateDimensionSet, tr.CreatePoint2d(ModelPosition.X, ModelPosition.Y))
ordDim.Text.FormattedText = ordDim.Text.FormattedText + "+"
End Sub
Cheers,
Adam Nagy
Autodesk Platform Services
