Edit field text from sketch symbol after placing
WIRMNS
WIRMNS
I have a piece of code where I have a sketch symbol put in my drawing.
Part of the text is already pre-filled. This are prompted entry text.
I want after placing the symbol that the Edit property fields pop-up is comming.
What is the best way to do it?
Dim oSketchedSymbolDef As SketchedSymbolDefinition
oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("Pos")
'Check To see If sketch symbol is on sheet
For Each actualSymbol As Inventor.SketchedSymbol In oDrawDoc.ActiveSheet.SketchedSymbols
' If sketched symbol is found
If (actualSymbol.Name = "Pos") Then
Return
Else
Next
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oPromptStrings(2) As String
oPromptStrings(0) = "1x" 'prompt 1
oPromptStrings(1) = "EN AW-5454" 'prompt 2
oPromptStrings(2) = "X" 'prompt 3
Dim oSketchedSymbol As SketchedSymbol
oSketchedSymbol = oSheet.SketchedSymbols.Add _
(oSketchedSymbolDef, oTG.CreatePoint2d(20.5, 4.5), 0, 1, oPromptStrings)
Michael.Navara
The easiest way is to execute appropriate command
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
dim oSheet as sheet = oDrawDoc.ActiveSheet
'Original code
		Return
	Else
Next
'End of Original code
oDrawDoc.SelectSet.Select(oSketchedSymbol)
ThisApplication.CommandManager.ControlDefinitions("DrawingEditFieldTextCmd").Execute
But cleaner than this solution is to implement your own edit dialog and update the prompted texts using API
WIRMNS
Thanks! This is what I want.
