- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a piece of code where I have a sketch symbol put in my drawing.
Part of the text is already pre-filled. This are prompted entry text.
I want after placing the symbol that the Edit property fields pop-up is comming.
What is the best way to do it?
Dim oSketchedSymbolDef As SketchedSymbolDefinition
oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("Pos")
'Check To see If sketch symbol is on sheet
For Each actualSymbol As Inventor.SketchedSymbol In oDrawDoc.ActiveSheet.SketchedSymbols
' If sketched symbol is found
If (actualSymbol.Name = "Pos") Then
Return
Else
End If
Next
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oPromptStrings(2) As String
oPromptStrings(0) = "1x" 'prompt 1
oPromptStrings(1) = "EN AW-5454" 'prompt 2
oPromptStrings(2) = "X" 'prompt 3
Dim oSketchedSymbol As SketchedSymbol
oSketchedSymbol = oSheet.SketchedSymbols.Add _
(oSketchedSymbolDef, oTG.CreatePoint2d(20.5, 4.5), 0, 1, oPromptStrings)
