edit a parameter in a different part - autonumber storage counter-iLogic
andrew_canfield
Message 1 of 10
andrew_canfield
Is there a way to use iLogic to update a parameter in a part (\top folder\count.ipt) given it's file path?
This parameter is used to hold a number - an external rule performs a save as (on a new file) reads the value from count.ipt, saves the file then add 1 to the parameter in count.ipt.
I had this working using Excel but it's throwing up a com error after a windows update..
Below is an external rule which loops saving a copy of the file you now have open. Reading the start number from an excel file (AutoNumberCounter.xlsx) - working before the windows update.
apologies - development code a bit messy..hopefully it provides a little more insight.
possibly replace 'AutoNumberCounter.xlsx' with 'count.ipt' - if the parameter can be edited?
'test rule to save as & increment number
xx= ThisDoc.PathAndFileName(True)
yy = ThisDoc.Path
MessageBox.Show(xx, yy)
aa = ThisDoc.FileName(False)
'without extension bb = number
bb = Right(aa, 5)
' extension
EXT1 = Right(xx, 4)
dd = Left(aa, 12)
'counter path
cp = Left(yy, 44)'copy the top folder location
an = cp & "AutoNumberCounter.xlsx"
ExNo = GoExcel.CellValue(an, "Sheet1", "A1")
ExNoS = CStr(ExNo)
'MessageBox.Show(an, ExNoS)
FrName = Left(aa, 12)
EdNameSt = Right(aa, 5)
Dim RepeatX As Integer
RepeatX = InputBox("How Many", "Incremental Save", "2")
StartNo = ExNo
EndNo = ExNo + RepeatX
For ee = 1 To RepeatX
'NameC6 = EdNameSt + ee
NameC6 = StartNo + ee
NameCt = "00000" & NameC6
EdName = Right(NameCt, 5)
'MessageBox.Show(EdName, NameCt)
'xx1 = ee
''yy1 = "00" & CStr(xx1)
'yy1 = CStr(xx1)
''mm = yy & "\" & bb & yy1 & cc
''mm = yy & "\" & bb & dd & yy1 & cc
mm = yy & "\" & FrName & EdName & EXT1
'MessageBox.Show(mm, CStr(EdName))
ThisDoc.Document.SaveAs(mm, True)
Next
GoExcel.CellValue(an, "Sheet1", "A1") = EndNo
MessageBox.Show("Save the xlxs - pop up behind Inventor", "Remember")
Regards
Andrew
Replies (9)
Message 2 of 10
A.Acheson
You can reference the document you want to edit with link here
And for access to UserParameters link here and some of code for component definition from the sample here
UserParameter.Value() As Variant
oDoc = Documents.Open( FullDocumentName As String, [OpenVisible] As Boolean ) As Document
partDoc =
oDoc
' Get the UserParameters collection
Dim UserParams As UserParameters
UserParams = partDoc.ComponentDefinition.Parameters.UserParameters
Dim UserParam As UserParameter
UserParam = UserParams(“Enter Name Here”)
UserParam.Value = UserParam.Value +1
Or alternately you should be able to use the ilogic snippet parameter reference here
 OParam=Parameter(partDoc.DisplayName,”Enter Parameter Name Here”).Value
OParam=OParam+1
Regards
Alan
Message 3 of 10
andrew_canfield
Many thank but this creates an error, "Reference to a non-shared member requires an object reference."
The part holding the parameter will open but I can't 'tunnel' into it to edit the parameter value.
Message 4 of 10
A.Acheson
This works for me.
Ensure the user parameter exist and that you have followed the same document reference down from when you opened this file.
Dim oDoc As Document
oDoc = ThisApplication.Documents.Open("ENTER FULL FILE PATH HERE", True)
Dim partDoc as PartDocument partDoc = oDoc ' Pass the object after opening to work with this part document ' Get the UserParameters collection Dim UserParams As UserParameters UserParams = partDoc.ComponentDefinition.Parameters.UserParameters Dim UserParam As UserParameter UserParam = UserParams(“Count”) 'Enter Parameter Name Here MessageBox.Show(UserParam.Value, "Count before adding") UserParam.Value = UserParam.Value + 1 MessageBox.Show(UserParam.Value, "Count after adding")
Regards
Alan
Message 5 of 10
andrew_canfield
Apologise, I'm pretty certain I've followed the instructions but..
Thankyou for the assistance.
Regards
Andrew
Message 6 of 10
A.Acheson
Unless you have a variable elsewhere in your image you are looking for the wrong parameter name. The name if string should be "CounterValue"
This error should come up as
Regards
Alan
Message 7 of 10
andrew_canfield
Sorry, my bad, I was testing with an additional parameter called 'xyz' along side 'Countervalue' the text did read 'CounterValue' but the same error occurs.
Message 8 of 10
andrew_canfield
Message 9 of 10
A.Acheson
You are offering a variable rather than a string value. Hence the not declared error.
String value has the quotes.
UserParam = UserParams(“CounterValue”) 'Enter Parameter Name Here
If you want to use a variable string.
Dim oName as String
Dim oName = "CounterValue"
Dim
UserParam As UserParameter UserParam = UserParams(oName) 'Enter Parameter Name Here
Regards
Alan
Message 10 of 10
andrew_canfield
Excellent - many thanks 🙂
Enjoyed the test too - edited to: (there was an extra Dim-second line)
Dim oName As String
Thanks Again
