Dynamic block, control visibility and a text field
S7RM7RPR
Message 1 of 1
S7RM7RPR
I'm attempting to create a dynamic block that will show a part detail, and display a specific text value description. The only way I've been able to get it to work, is by using two different blocks so that I can have two visibility states. I want to be able to have it as a single block, but I can't quite figure out how to get it done.
I've been trying to see if I can use the Block Table, but I can't figure out how to handle the text value without having 156 different visibility states. I thought to try to use the table parameter in an attribute, but I can't figure out how/if I can use a user parameter in an attribute.
I've attached the dual block file, if anyone has any thoughts as how to handle this please let me know!
As a note, I'm attempting to set this up without resorting to macros. I'd like to keep this strictly as a dynamic block for now
Replies (0)
