- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We manufacture sheet metal parts using Radan and export our flat patterns from inventor into Radan using the DTM plugin.
Whenever we transfer a file the filename from the top of the history tree is exported as the part name and etched onto the part using a macro.
as you can see the .ipt is transferred through with the part and is then used in the file name and etched onto the part unless removed manually.
Is there a way of turning the extension off inside inventor?
We have tried hiding the file extensions in windows but it is still picking it up.
We can manually remove the .ipt but this is usually overlooked creating double work as we go back to remove it. Sorry if this is trivial but we do it on a lot of parts so the time it takes adds up.
