Drive Constraints via API - 2nd Try
MattH_Work
MattH_Work
What mechanism does the 'Drive Constraint' command use to modify constraints and is it accessible via the API
Doing a small test program (VB.NET addin) I can get an update rate of around 2 per second in my test Assembly (changing parameter value and then rebuilding Assembly) whereas I can get substantially better performance (ie smooth movement / 10's of updates per second) when RMB'ing on the constraint and selecting 'Drive Constraint'
Regards
MattH
MattH
Product Design Collection 2026
Vault Pro 2026
I'm not sure, but is it possible it uses the studio environment.
Brett.G
this would be nice to know...
