Drive a excel file with userform
Message 1 of 16
Hello
I what to learn about iLogic rules and codes and i have seen ther is this User Form.
So, i make a excel file with parameters: "Höhe", "Breite" and "Länge".
The Parameter Länge change its value when i change "Höhe" und "Breite".
The exel tabell ist linked externaly with the part. i use excel 2013 and inventor 2015.
Is it posible to make a userfrom, that consist of "Höhe" und "Breite" field to cnage the "Länge" parameter?
I make a userform but its only a sample what i whant. I cnt chance it
Replies (15)
Message 2 of 16
Jacques.Grobler
Hi Alesandar
Is there a reason why you want to use excel userform and not only use iLogic?
iLogic has its own built-in forms.
Message 3 of 16
Hello and than you for the replay
Because, my excel ist with formulas linked
i can not do ROUND....or?
A know how to link parameters from parameter tabell in invenotr in a user form, but it is posible to make it with excel.
Message 4 of 16
Jacques.Grobler
Sorry for the many questions...
1. You want to write an Excel userform to fill in values in Excel, and then iLogic updates the part?
OR
2. You want to have an iLogic userform that sends "Höhe" and "Breite" to Excel, which calculates "Länge" and send that back to Inventor?
Message 5 of 16
The answer 2.
To calculate the "Länge". To keep the formula in the userform (to link the formula from excel with user form), that i can calculate it
Message 6 of 16
Jacques.Grobler
Ok
So here are some references that will help you with the passing of parameters from Inventor to Excel:
The youtube is very simple in my opinion...
https://www.youtube.com/watch?v=eJ0MiDVJvOc
http://forums.autodesk.com/t5/inventor-general-discussion/how-do-i-export-ilogic-parameters-into-exc...
and here is a reference that will help you with creating an iLogic userform:
http://www.inventortales.com/2012/06/using-ilogic-form-to-make-rule-user.html
I hope this helps you on your journey
Message 7 of 16
Much thanks but this is for export parameters to excel
I want to export parapters from excel to user form
Message 8 of 16
Jacques.Grobler
I missed htat you already have a userform in inventor...
So your inputs on the userform is readonly because Excel has "control" of those parameters...
What I would have done was create 2 extra parameters, maybe called excel_Breite and excel_Hohe under the parameters, and then have the iLogic form point to them, then export them to excel, then excel would import the new values...
Message 9 of 16
https://www.youtube.com/watch?v=jUeKUbr2km4
I have found this Video.
Here is a code
ExcelFile = "C:\Users\Aleksandar.Jovicic\Desktop\Probe iLogic\Probe iLogic" & iProperties.Value("Custom", "PropertyName") &".xlsx"
What means: "PropertyName" ? Where are this properies in my part?
I this video he writes: "Order Number"
Message 10 of 16
Jacques.Grobler
The propertyname referes to a ciustom property that you can create under iproperties.
So he would have gone and created a custom iproperty called "Order Number"
Are you trying to work between 2 different excel files or the same 1?
Message 11 of 16
I want only one excel linked with inventor on a assembly/part and to drive it with my user from
Message 12 of 16
Jacques.Grobler
Have you had a look at the part and excel I attached?
Message 13 of 16
yes thats exactly what i want
thaks!
can i whrait with this a much complexer exel tabel?
Message 14 of 16
Jacques.Grobler
Yes you can
Message 15 of 16
Hello again
I have tried just to edt the part, to create i hole
The hole have min and max diameter, and i have choose the average
But, i cant insert the parameter "Loch" in my userform
When i save the file it will be deleted
i put just:
GoExcel.CellValue(filePath, "Tabelle1", "B2") = excel_Loch
and the "excel_Loch" is not blue
Message 16 of 16
Jacques.Grobler
The fact that "excel_Loch" is red not blue is because iLogic is telling you that it doesn't know which parameter you are pointing at, so you first have to go and add the parameter under your parameters...  Manage -> Parameters
Then next you will see that all your excel references under parameters are marked in yellow, this indicates that Inventor thinks something is wrong with your excel and when you want to rebuild, it will not update model.  This is because your Hohe value (B2) is empty. Never use an empty cell, if you don't want a value there, put a 0.
Then try run again and let me know if it does what you want
