DrawingViewHatchArea.Rangebox does not respect Break Operations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a script that adds material leaders to each hatch region. When I'm selecting which drawing curve to connect to I want to avoid drawing curves of the surfacebody which do not bound the hatch region. To do this I am checking if the points of the drawing curves are within the Rangebox of the HatchArea. This works well in most situations except when the drawing view has any break operations
I have found out that the rangebox of the hatcharea can be outside of the DrawingView boundary when the DrawingView has a break operation. Unfortunately this does not align with the drawing curves as they do respect the break operation, so I'm not able to filter DrawingCurves for DrawingViews with Break operations. I feel like this should not be the intended behavior.
This is a simple test:
Sub Main
Dim PickThis As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select")
If IsNothing(PickThis) Then Exit Sub ' If nothing gets selected then we're done
Dim DVbox As Box2d = GetBoxFromView(PickThis)
DVbox.Expand(.001) 'increases by .001 cm in each direction because Area Rangeboxes @ edges of view sometimes return false when "Exact" box is used
For Each DVHR As DrawingViewHatchRegion In PickThis.HatchRegions
Dim BoundaryGeometries As ObjectCollection
Try
BoundaryGeometries = DVHR.BoundaryGeometries
Catch
Continue For 'This is the only way to avoid the extra HatchRegions. Throws error instead of returning nothing when the "HatchRegion" doesn't actual bound a hatch region
End Try
Try
For Each HA As DrawingViewHatchArea In DVHR.HatchAreas
Dim tempBox As Box2d = HA.RangeBox.Copy
Logger.Trace(String.Format("MinPoint inside view: {1} | MaxPoint inside view: {2} | Area SurfaceBody name: {0}", DVHR.SurfaceBody.Name, DVBox.Contains(tempBox.MinPoint), DVBox.Contains(tempBox.MaxPoint)))
Next
Catch : End Try
Next
End Sub
Function GetBoxFromView(parentDrawingView As DrawingView) As Box2d
Dim MinPoint, MaxPoint As Point2d
MinPoint = parentDrawingView.Center.Copy
MinPoint.X -= parentDrawingView.Width / 2
MinPoint.Y -= parentDrawingView.Height / 2
MaxPoint = MinPoint.Copy
MaxPoint.X += parentDrawingView.Width
MaxPoint.Y += parentDrawingView.Height
GetBoxFromView = ThisApplication.TransientGeometry.CreateBox2d
GetBoxFromView.MinPoint = MinPoint
GetBoxFromView.MaxPoint = MaxPoint
Return GetBoxFromView
End Function
it should return all true for views which do not have any break operations, but returns some false if there are break operations.
I would like to know if anyone can think of a workaround, and more importantly if this is even supposed to be the intended behavior.
