Drawingsketch projected geometry get reference
Caduser1FQQYS
Caduser1FQQYS
Hey,
i have a sketch where i project centerlines from the sheet
oSketchEntity = oSketch.AddByProjectingEntity(ocl)
 now when i run this rule a second time and it shouldn't add the line but get the correct sketchentity object
			For Each oLine As SketchLine In oSketch.SketchLines
				If oLine.ReferenceComponent.Name = ocl.Name Then
					oSketchEntity = oLine
				End If
			Next
 this won't work because there is no reference component to that line.
Although i'm sure every line in that sketch is added by the projectingentity method.
So how can i go from a sketchline object back to the centerline object.
Ralf_Krieg
Hello
Late, but have you tried the oLine.ReferencedEntity instead?
R. Krieg
RKW Solutions
www.rkw-solutions.com
