DrawingDimension text position
Is there a way to determine if the drawing dimension text is on the left, in the middle or on the right? Of course this can be done with math, but it becomes dificult when the dimensions are not horizontal or vertical but aligned in certains angles. I could not find a way that worked in all situations, mainly because the direction I used changed and left / right switched. Startpoint and endpoint of a dimension for example can switch depending on the situation. The same is true for the direction of the dimension line.
