DrawingDimension text position
tobias_wiesendanger
tobias_wiesendanger
Is there a way to determine if the drawing dimension text is on the left, in the middle or on the right? Of course this can be done with math, but it becomes dificult when the dimensions are not horizontal or vertical but aligned in certains angles. I could not find a way that worked in all situations, mainly because the direction I used changed and left / right switched. Startpoint and endpoint of a dimension for example can switch depending on the situation. The same is true for the direction of the dimension line.
A.Acheson
Hi @tobias_wiesendanger
Middle is relatively easy getting the mid distance between the two intent points, figuring out if you want it on the left or right is a user decision so what factors make this decision in the code?
In relatively simple horizontal and vertical dims scenarios I have just placed a block of code in to determine the direction required based on two face being left or right of center and then adjust the text offsets + or -accordingly.
Regards
Alan
tobias_wiesendanger
Its not like I have to place dimension. Im just iterating over all of them and I need to know where the text is. I think I found a solution for it. It is possible to assume that the smaller x-koordinate of a dimensionLine is on the left. So its possible to check if drawingDim.Dimensionline.Startpoint > drawingDim.Dimensionline.Endpoint and if yes just switch the points. This then allows to have the same situation every time. It no longer matters what angle the dimension has. From there its just checkin if drawingDim.Text.Origin is left, right of those points.
