DrawingCurveSegment and AttributeSets
Afternoon All,
I have a template part with a drawing that I copy to new projects. So the part gets resized and saved as a new file, the drawing as a new file and then replace reference in the new drawing file with the new part file.
What I'm trying to do is associate a drawing dimension with an DrawingCurveSegment so I can basically look at the curve X and Y start and end locations and calculate where my drawing dimension should be moved to.
Everything works I just have no way of identifying the drawing curve after the new file save. I used the GetHashCode of the drawing curve segment but this number changes when I saved it as a new file.
Is there an attibute set or similar I can use to somehow label the DrawingCurve that I want?
adam.nagy
Autodesk Support
Autodesk Support
Hi Andrew,
If you know the model curve the drawing curve is representing that you should be OK, since there is a connection between the two: you can definitely get to the model curve from the drawing curve directly, and I think you can do it the other way round as well.
Let me know if you need more info.
Cheers,
Adam Nagy
Autodesk Platform Services
