Drawing View Label should be shown as per Designer With iLogic
dechandan94
Observer Observer
dechandan94
Observer
Observer
Whenever I will create drafting view of any sheet metal parts so my first View Always coming as a Front View but I want to Decide which is front then Remaining view will come as per decided View,
I got iLogic Code for that Automatically coming label but still View problem,
please Help me.
dalton98
I'm confused about what your asking. Are you saying the different designers start on different planes? xy, zy, zx? If the view is a flat pattern it should fix this automatically. You can also right click the cube in the part document to set the 'Front View'. If you could explain your work flow that might help with answering the question.
