an array of simple components with varying angle constraints.
so far there is a few ways to do this, that' ive researched, my illogic being, just terrible. the simples way for me would be to create a sketch based pattern with lines spaced x_step apart, total number of 40, and each step, the line angles by 2.25 degrees.
then using imates, I will constrain the "simple component" to these lines, and pattern for what i'm needing.
**how can I use ilogic to create a pattern where the 40 lines are created, each one increases by 2.25 degrees.
I'm not attaching a file, because I don't see a need for that.
remember you are talking to a ilogic newb (so acronyms will not make sence to me); but I have found these resources; just struggling to put the pieces together.
option one is something like this: and then i'd have to still figure out the array.
https://modthemachine.typepad.com/my_weblog/2012/04/drawing-in-a-sketch.html
:this is option 2 to pattern and vary the angle using ilogic.
this whole thing is confusing to be because if i could just index each step (of the pattern) i could just multiply the next step by 2.25 and manipulate it that way; no idea how to code this in illogic, maybe MATLAB if i could remember the syntax.
thanks all
-mda
