Drawing template objects
On my company's default drawing template, I have a text block on there with some drawing notes. We often edit some of the notes on the end at each drawing so I didn't create it on the "title block" layer, rather it's on the "top" layer. I also added (in the template) a revision table with Rev. A being "Released for Production" (because we are weird). How can I constrain those on the sheet so when I change sheet size, they stay in the same position relative to the corners of the sheet?
Thanks!
philippe.leefsma
I don't think it is possible to constraint something on the sheet, if you are looking for a custom solution that involves programming, then you could reposition those notes after some event has been triggered, I would need to check in details which one you could use in case of a sheet size change.
If you are looking for a non programatic solution, then you are in the wrong place, this section of the forum focuses uniquely on Inventor customization through its API or iLogic. You will have more luck asking your question in the user section: http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
