DRAWING SHEET iLogic - Ordinate Dimension overides
I would like to be able to select an ordinate dimension set and over ride the first dimension in the set
1. Select a dimension set
2. set  Dimension Appearance to Basic
3. Hide dimension value (which is 0)
4. add Text '01'
5. Have three button options for the text '01' '02' '03'
I am a newb to ilogic so any help would be greatly appreciated
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try the below iLogic code to select number and rename ordinate dimension.
Sub Main()
	Dim oDimension As DrawingDimension
	oDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick a Ordinate dimension to rename")
	If oDimension.Type = ObjectTypeEnum.kOrdinateDimensionObject Then
		Dim oList As ArrayList = New ArrayList()
		oList.Add("01")
		oList.Add("02")
		oList.Add("03")
		selected_num = InputListBox("Choose number to rename", oList, oList.Item(0), "Numbers list", "List of numbers to rename ordinate dimension")
		oDimension.HideValue = True
		Select Case selected_num
		Case "01"
			oDimension.Text.FormattedText = "01"
		Case "02"
			oDimension.Text.FormattedText = "02"
		Case "03"
			oDimension.Text.FormattedText = "03"
		End Select
	Else
	    MsgBox ("Selected drawing dimension is not ordinate dimension")
	    Exit Sub
	End If
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Hi, Thanks so much for your help. The code works fine. I was however hoping to change the appearance of the first dimension so that it appears as 'Basic' in the 'Precision and Tolerance' tab in the dimension editor.  See attached picture.
Thanks again
Peter
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to convert tolerance type to basic.
Sub Main()
		oList.Add("01")
		oList.Add("02")
		oList.Add("03")
		Case "01"
		Case "02"
		Case "03"
		End Select
		Call oDimension.Tolerance.SetToBasic()
	Else
	    Exit Sub
	End If
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Wow thanks This is great
