Drawing Resource Transfer Wizard failed to open source file
patrickl2
patrickl2
Hello guys,
I was trying to use the Drawing Resource Transfer Wizard. However I got the error message shown below when i opened source file. I disabled the automatic load of ilogic already. Could anyone help on it? Thank you
A-M-Z
Very annoying, same problem here, in 2025, I need to update a lot of title blocks, but can't.
Tried older versions, unloading add-ins, clearing everything from the source drawing.
Place it on different locations, in or outside the project, but always getting the same error.
Takes long, about a minute before the error appears.
The problem is known by autodesk:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Drawing-Resource-T...
That's a start,  and now................?
Seems not everyone has this issue, there would probably be more responses on this thread.
But has Anybody found a work around?
Greetings
A.M.Z.
Inventor 2025 /Vault Basic
A-M-Z
One thing I did not try: Start Resource Transfer Wizard as Administrator, and that fixed it!
Never had to do this before, but now I can continue.
