Drawing iLogic - Place Views Using For Loop
lukerNEVB8
lukerNEVB8
I have the following code as an example, is there correct syntax for me to say:
For i = 1 to 4
     oView & i = oSheet.DrawingViews.Item(i)
Next
Dim oView1, oView2, oView3, oView4 As DrawingView
oView1 = oSheet.DrawingViews.Item(1)
oView2 = oSheet.DrawingViews.Item(2)
oView3 = oSheet.DrawingViews.Item(3)
oView4 = oSheet.DrawingViews.Item(4)
I cannot seem to find a way to get iLogic to reference oView1 in this way. Code later creates workpoints and centerpoints and ideally I want to do the same thing.
Thanks!
JelteDeJong
You might have  a look at arrays. you could do something like this:
Dim oView(sheet.DrawingViews.Count) As DrawingView
For i = 1 To sheet.DrawingViews.Count
    oView(i) = sheet.DrawingViews.Item(i)
Next
For Each currentView As DrawingView In oView
    ' Arrays have also a element 0.
    ' We did only set elements 1 to 4.
    ' There for element 0 is nothing. and we have
    If (currentView Is Nothing) Then Continue For
    MsgBox(currentView.Name)
Next
There is alos a easyer way to fill the array. If you use this then you elements 0 to 3 are filled. (computers usally start counting with 0)
Dim oView() As DrawingView = sheet.DrawingViews.Cast(Of DrawingView).ToArray()
Next
Jelte de Jong
Blog: hjalte.nl - github.com
