Drawing dimension
Drawing dimension
kv5053545
Drawing dimension
kv5053545
Sub main()
    Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
    Dim oActiveSheet As Sheet = oDoc.ActiveSheet
    For Each oDrawingView As DrawingView In oActiveSheet.DrawingViews
        If oDrawingView.Name = "VIEW6" Then
            Dim oRefDoc As AssemblyDocument = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
            Dim oAssDef As AssemblyComponentDefinition = oRefDoc.ComponentDefinition
            Dim oOcc As ComponentOccurrence
            For Each oOcc In oAssDef.Occurrences
                Dim oSubOcc As ComponentOccurrence
                For Each oSubOcc In oOcc.SubOccurrences
                    Dim componente As String = oSubOcc.Name
                 If componente.Contains("Gaskets:1") Then
				       MessageBox.Show(componente)
                    Dim oSubSubOcc As ComponentOccurrence
                    For Each oSubSubOcc In oSubOcc.SubOccurrences
                        Dim subComponente As String = oSubSubOcc.Name
						If subComponente.Contains("Gasket:1") Then
							 MessageBox.Show(subComponente)
							  Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
                        Dim VIEW6 = Sheet_1.DrawingViews.ItemByName("VIEW6")
                        Dim namedGeometry1 = VIEW6.GetIntent(subComponente,"WP_GasketTop")
                        Dim namedGeometry2 = VIEW6.GetIntent(subComponente, "WP_GasketBottom")
                        Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
                        Dim dimX = -0.02
                        Dim dimY = -0.02
                        Dim linDim1 = genDims.AddLinear("Dimension 1" & componente, VIEW6.SheetPoint(dimX, dimY), namedGeometry1, namedGeometry2)
						End If
                    Next
				End If
                Next
            Next
        End If
    Next
End Sub
I have this code to generate dimensions in a drawing but I have this error
GetIntent("Gasket:1", "WP_GasketTop"): The component named "Gasket:1" was not found, what I don't understand is why it doesn't find the component if in a previous if it finds it.
I don't know if there is something I'm not seeing right in the code, I would appreciate your help!
A.Acheson
Hi @kv5053545
Can you confirm what error message your getting and which line the code errors out on?
Also are you sure the occurrence name is an acceptable argument for the Get Intent method. Help page shown here
Regards
Alan
cadconfigurator
Is it possibly a typo? Gaskets:1 <--> Gasket:1
kv5053545
Hi @A.Acheson, This is the error that appears in line 29, as far as I understand it is a value that accepts the GetIntent
This is how it appears in the model:
WCrihfield
Hi @kv5053545.  It looks like your spelling and capitalization are correct, however, since that component is within a sub assembly, you need to specify more than just its name.  You need to specify the 'Path' of that component.  The path is an Array of Strings, starting with the name of the top level component that represents the sub assembly, then the name of the component within that sub assembly.
When you look at the online documentation for IManagedDrawingView.GetIntent Method (there are two versions of this method, the other one is at this link), you will see that the first 'input' being requested is called a ComponentArgument.  This 'type' of object is odd, because it can be specified with a single String (the name of a component, if it is top level), or an Array of Strings (if it is a component within a sub assembly), or an IManagedComponentOccurrence object.  In your case, it would be the second option.  Similar to the MakePath iLogic tool, but I don't think it is looking for that tool here.
Wesley Crihfield
(Not an Autodesk Employee)
kv5053545
Hi, Thank you very much it was just what I needed
