Drawing Dimension Object
Hey,
Has anyone Information where in witch Object is this Saved
Its Nothing to find in Dimension / Text
or Dimession Toolearance...
Thx for Help or Sugesstion
Mario
its Inventor 2014 / .net VB or vba or C#
JoAnn_Hogan
Did you have a look at the styles editor? Maybe you can give me an example?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
philippe.leefsma
Those are the inspection dimension data, you need to retrieve that info using GetInspectionDimensionData method:
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    Dim oDoc As Inventor.Document
    Set oDoc = oApp.ActiveEditDocument
    Dim dimension As GeneralDimension
    Set dimension = oDoc.SelectSet(1)
    Dim shape As InspectionDimensionShapeEnum
    Dim label As String
    Dim rate As String
    Call dimension.GetInspectionDimensionData(shape, label, rate)
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
thx
it works great!
Mario
