Draw Line Between Two Selected points in Part Sketch
inulobo
inulobo
How do you collect two selected sketch points, get their sketch point2d geometry, and draw a line to connect the selected points.
FINET_Laurent
Maybe having a look at this whould help?
https://forums.autodesk.com/t5/inventor-customization/ilogic-sketch-creation/m-p/4906204/highlight/t...
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
inulobo
Not exactly what I am looking for. That seems to work with given inputs. I am trying to have it use 2 selected points as my inputs. How do I grab the two selected or active points?
inulobo
This is as close as I have gotten. I have to select the two points after I run it. I cannot figure out a way to work with preselected points.
Public Sub JoinPoints()
    'set a reference to the active sketch.
    Dim oSketch As PlanarSketch
    Set oSketch = ThisApplication.ActiveEditObject
    Dim oSketchPoints As SketchPoints
    Set oSketchPoints = oSketch.SketchPoints
    Dim skPoint As SketchPoint
    Set skPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select point")
    Dim skPoint2 As SketchPoint
    Set skPoint2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select second point")
    Dim oLines As SketchLine
    Set oLines = oSketch.SketchLines.AddByTwoPoints(skPoint, skPoint2)
End Sub
JhoelForshav
@inulobo
If the points are selected they will be in the documents selectset. I wrote this macro for you. Make sure there are only two selected entities and that they are two sketchpoints in the same sketch 🙂
Dim oSelSet As SelectSet
Set oSelSet = ThisApplication.ActiveDocument.SelectSet
If oSelSet.Count = 2 Then
If TypeOf oSelSet(1) Is SketchPoint And TypeOf oSelSet(2) Is SketchPoint Then
    Call oSelSet(1).Parent.SketchLines.AddByTwoPoints(oSelSet(1), oSelSet(2))
End Sub
