Arrange Dimensions / Fix Dimensions
Hello Everybody,
I have a drawing document with a Parameterized model. I made a Form with some iLogic rules to get the parameters, replace them in the 3D model, update the model and change scale of the view, and then retrieve dimensions in the drawing. My Problem is that when I retrieve dimensions after I change the parameters they get mixed up. I have arranged them in my sketch, but when parameters change and thus the model, these dimensions will move and then when I retrieve them they are mixed.
Can you suggest any solution for this problem ? Is there anyway to fix dimensions with respect to the geometry so that they follow the geometry ?   I tried the Arrange dimensions command but it will move the dimensions far away from the model.
Thanks in advance.
ernis
Look here. there much discussed about dimensional alignment, there is an example of iLogic. Maybe what will happen...
