Document.ReferencedDocuments is implemented as a stack, why?
CattabianiI
CattabianiI
Out of curiosity why `Document.ReferencedDocuments` is implemented as a stack?
To try that:
1. open an assembly
2. add these lines in an iLogic rule:
SyntaxEditor Code Snippet
Dim doc As Document = ThisApplication.ActiveDocument
MsgBox(doc.ReferencedDocuments.Item(1).FullFileName)
3. place one document
4. run the rule
5. repeat from step 3
dgreatice
use this:
Dim RefDoc As Document
For Each RefDoc In doc.ReferencedDocuments
	MsgBox(RefDoc.FullFileName)
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
