Dockable Windows - OnClose Event?
MattH_Work
MattH_Work
I can successfully create a dockable window (browser), which then displays my user form correctly using similar code to this
Dim oUserInterfaceMgr As UserInterfaceManager
oUserInterfaceMgr = m_inventorApplication.UserInterfaceManager
oWindow = Nothing
Try
oWindow = oUserInterfaceMgr.DockableWindows.Add(m_ClientId, "String1", "String2")
Catch
oWindow = oUserInterfaceMgr.DockableWindows.Item("String1")
End Try
oWindow.AddChild(oForm.Handle)
oWindow.DisabledDockingStates = DockingStateEnum.kDockTop + DockingStateEnum.kDockBottom
oWindow.DockingState = DockingStateEnum.kDockLeft
oWindow.SetMinimumSize(oWindow_Height, oWindow_Width)
oWindow.Visible = True
However, if I close the dockable window in Inventor and reopen it, it still displays the form with its current settings, rather than the original base form. The form seems to be still open, even if the window is not
How do I send a signal to my form to fully close when the user clicks the dockable windows 'X' button?
In essence, is there an onclose event for dockable windows
Regards
MattH
MattH
Product Design Collection 2026
Vault Pro 2026
YuhanZhang
You can use the OnHide event in this case.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
MattH_Work
What would be the simplest way to implement an OnHide event for a dockable window
MattH
Vault Pro 2026
YuhanZhang
In UI when you click the 'x' button it just hides the dockable window/browser but not close/delete it, when you click the '+' button you can see a dropdown list and choose one browser/dockable window to display will make it visible. So you can see the API side exposes the DockableWindowsEvents.OnHide/OnShow events for the behavior. And I attached a simple VBA sample to demonstrate how to use them, you can load the IVB and run the DockableWinShowHideSample function, and then show/hide the dockable windows to see the  events are fired.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
MattH_Work
The ZIP file seems to be emtpy
MattH
Vault Pro 2026
YuhanZhang
Re-attached it, please check it.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
