Dimension Snap in Break
When I automaticly add dimensions to my drawing, it shows the dimension snap within the break (as shown on the picture).
In VB.net I'm looking for all the lines that need an dimension, order them from top to bottom and then add dimension as LinearGeneralDimension.
The dimension line is snapped on a point in the line where the break is.
Is there a possibility to get the dimension snap outside the break through iLogic or VB.net?
Cadmanto
That is because the reference was taken from that side.  Just drag them over to the left side.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
@Cadmanto
Thanks for the reply, but that's not the solution to my problem
It will be an automated process where the dimensions are automaticly added to the drawing.
After that it will be automaticly printed and closed so I can't make any edits to that drawing or the dimensions.
I need an solution within iLogic or VB.net so the problem won't happen again.
Cadmanto
Fair enough.  I don't know iLogic, so I can't help you there.
My suggestion would be to have this posted in the customization forum.
I will contact the moderator and have him move this over.
Inventor Pro 2018
Best Regards,
Scott McFadden
