Do I use UserInputEvents correctly?
strandvata
strandvata
Greatings to all!
I would like to make a simple no-user-interface addin for Inventor in VB.NET. My plugin is for drawing files only so I use LoadBehaviour = 4 in the addin manifest file. I would like to register with UserInputEvents and do stuff when certain commands have finished thair execution. I use VS Express 2013 for Desktop and Autodesk Inventor 2015.
I used this example from the API Help to get a list of the available commands:
Sub PrintCommandNames()
    Dim oControlDefs As ControlDefinitions
    Set oControlDefs = ThisApplication.CommandManager.ControlDefinitions
    Dim oControlDef As ControlDefinition
    Open "C:\temp\CommandNames.txt" For Output As #1
    Print #1, Tab(10); "Command Name"; Tab(75); "Description"; vbNewLine
    For Each oControlDef In oControlDefs
        Print #1, oControlDef.InternalName; Tab(55); oControlDef.DescriptionText
    Next
    Close #1
End Sub
In my OnTerminateCommand event handler I have this code:
Private Sub UserInputEvents_OnTerminateCommand(ByVal CommandName As String, ByVal Context As NameValueMap)
	Dim sDocName As String = m_inventorApplication.ActiveDocument.DisplayName
	If m_inventorApplication.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		If CommandName = "AppFilePrintCmd" Then
			' do stuff
		End If
		If (CommandName = "DrawingNewSheetCtxCmd") Then
			' do stuff
		End If
		If (CommandName = "DrawingDeleteSheetCtxCmd") Then
			' do stuff
		End If
	End If
End Sub
And it seems to work when I add new sheet (DrawingNewSheetCtxCmd) though I believe it fires before it adds the sheet. The problem is that nothing happens when I delete a sheet (DrawingDeleteSheetCtxCmd).
I guess I don’t use the right event (OnTerminateCommand) or even the right group of events (UserInputEvents). Please help me understand what I do wrong!
Thank you in advance,
Ivan
Here is the code of whole addin:
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Imports System.IO
Imports System.Drawing
Imports System.Windows.Forms
Namespace DWG_Toolbox
    <ProgIdAttribute("DWG_Toolbox.StandardAddInServer"), _
    GuidAttribute("82557d17-f70d-48c1-a839-590d8bd91334")> _
    Public Class StandardAddInServer
        Implements Inventor.ApplicationAddInServer
        Private m_inventorApplication As Inventor.Application
        Dim m_UIEvents As Inventor.UserInputEvents
        Dim m_DocEvents As Inventor.DocumentEvents
#Region "ApplicationAddInServer Members"
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' This method is called by Inventor when it loads the AddIn.
            ' The AddInSiteObject provides access to the Inventor Application object.
            ' The FirstTime flag indicates if the AddIn is loaded for the first time.
            ' Initialize AddIn members.
            m_inventorApplication = addInSiteObject.Application
            ' TODO:  Add ApplicationAddInServer.Activate implementation.
            ' e.g. event initialization, command creation etc.
            m_UIEvents = m_inventorApplication.CommandManager.UserInputEvents
            AddHandler m_UIEvents.OnTerminateCommand, AddressOf UserInputEvents_OnTerminateCommand
            'mAsmCommandBar.Controls.AddButton(mSettingsButtonDef, 0)
        End Sub
        Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
            ' This method is called by Inventor when the AddIn is unloaded.
            ' The AddIn will be unloaded either manually by the user or
            ' when the Inventor session is terminated.
            ' TODO:  Add ApplicationAddInServer.Deactivate implementation
            ' Release objects.
            RemoveHandler m_UIEvents.OnTerminateCommand, AddressOf UserInputEvents_OnTerminateCommand
            m_UIEvents = Nothing
            m_inventorApplication = Nothing
            System.GC.Collect()
            System.GC.WaitForPendingFinalizers()
        End Sub
        Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation
            ' This property is provided to allow the AddIn to expose an API
            ' of its own to other programs. Typically, this  would be done by
            ' implementing the AddIn's API interface in a class and returning
            ' that class object through this property.
            Get
                Return Nothing
            End Get
        End Property
        Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand
            ' Note:this method is now obsolete, you should use the
            ' ControlDefinition functionality for implementing commands.
        End Sub
#End Region
                    ' do stuff
                End If
		    ' do stuff
                End If
		    ' do stuff
                End If
	End If
        End Sub
    End Class
End Namespace
Ivan Temelkov
Autodesk Inventor Customization Enthusiast
www.inventiveworkflows.it
strandvata
Maybe I found the answer myself.
I played with the Event Watcher (a program included in the SDK) and it seams that in order to capture the events related to new dwg sheet and delete dog sheet I have to use TransactionEvents.OnCommit.
I'll give more detail when I try it.
Ivan
Ivan Temelkov
