Do all custom iProperties require a string output?
- Mute
- Permalink
- Report
I'm trying to set up a code where I can update an iProperty based on inputs. I modified the example code to update iProperties. The sub would be used with texts, bools, and numbers. I set the input as a variant but get errors if I pass anything other than a variant or string. What's the rules on iProps?
Public Sub CalliProp() Dim docCurr As Document Set docCurr = ThisApplication.ActiveDocument Dim dblTest As Double dblTest = 3.22222 Call UpdateCustomiProp(docCurr, "Woohah", dblTest) End Sub Public Sub UpdateCustomiProp(docDoc As Document, strPropTitle As String, varValue As Variant) ' Get the custom property set. Dim psCustom As PropertySet Set psCustom = docDoc.PropertySets.Item("Inventor User Defined Properties") Dim propCurrent As Property Set propCurrent = psCustom.Item(strPropTitle) If Err.Number <> 0 Then ' Failed to get the property, which means it doesn't exist ' so we'll create it. Call psCustom.Add(varValue, strPropTitle) Else ' Got the property so update the value. propCurrent.Value = varValue End If End Sub
