Distance between two faces in assy as a parameter
GoranBe
Message 1 of 23
GoranBe
Hello
What is the easiest way to get distance between two faces, store it into some user parameter and have the value updated if the distance changes. From experience I know that if I Measure the parameter value it will not update, if the distance changes. I tried to create dimension annotation in model, but I am not aware of how to use it's value as a parameter. In short, I'd like to have 47,00 mm dimension value from the picture below stored in the (named) parameter and updated, if it changes due to any reason - housing height change, constrains change etc...
Thanks for your ideas
Goran
Replies (22)
Message 21 of 23
JhoelForshav
hi @GoranBe
Try this iLogic to get the 3D dimension value:
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oCompDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
Dim oDimension As LinearModelDimension
oDimension = oCompDef.ModelAnnotations.ModelDimensions.LinearModelDimensions.Item("OHa")
Dim oValue As Double = oDimension.ModelValue 'Database units (cm)
MsgBox(oValue)
Dim oValue2 As Double = CDbl(oDimension.Definition.Text.Text) 'Convert the actual dimension text to double
MsgBox(oValue2)
Message 22 of 23
GoranBe
Jhoel,
you made my day, thanks. @JhoelForshav, just one more question if I may - in your opinion what is the best source to learn iLogic objects? Me personally I just couldn't find "...ModelAnnotations.ModelDimension..." in online help resources for example.
Thanks again
Goran
Message 23 of 23
JhoelForshav
Hi @GoranBe
I usually inspect the objects by simply typing in the iLogic editor
But klicking your way through the objects in the API help is also a good way.
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-D675E860-ADB7-4771-ADAB-2EEEB214F9EC
If i have no clue where to start i usually search this forum or do a google search to find some object related to what I'm trying to do 🙂
