Display option referenced parts
MairA_DUKA
MairA_DUKA
Good evening
I have a View from an Assembly. The Assembly has referenced parts.
The referenced parts are showing through other components in drawing views.
I want create an iLogic-Rule to change the view from this:
to this:
To recive this I have to change the settings from this:
to this:
This is my iLogic Rule, but I can't finde the right option/parameter to change the setting from the image above.
Try
Dim oDoc As Document
oDoc = ThisDoc.Document
If (oDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject) Then
Dim oView As DrawingView = Nothing
Dim oDrawingViews As DrawingViews
Dim NewArrayList As New ArrayList
oDrawingViews = ThisApplication.ActiveDocument.ActiveSheet.DrawingViews
For i = 1 To oDrawingViews.Count
oView = oDrawingViews.Item(i)
Next
End If
Catch ex As Exception
MessageBox.Show(ex.Message, "Error iLogic-Rule View REF")
End Try
WCrihfield
That's a tough one.  I don't see any option in for a DrawingView that gives you access to those settings.
You can review the current help file for the DrawingView Object at the link below.
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-D273D9C3-C24F-4CDD-B571-F2C0B5F7A5B3
Wesley Crihfield
(Not an Autodesk Employee)
chandra.shekar.g
Autodesk Support
Autodesk Support
@MairA_DUKA,
Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
WCrihfield
I created it here...
https://forums.autodesk.com/t5/inventor-ideas/drawing-view-model-state-hidden-line-calc-amp-line-sty...
Thanks for the tip.
Wesley Crihfield
chandra.shekar.g
Autodesk Support
Autodesk Support
@WCrihfield,
Thanks for creating wish list at idea station,
Engineering team may be considered based on vote for this wish list.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
