Display name problem
Olgan
Olgan
hi,
i have a weird problem. I've attached 4 images. Shouldn't the underlined display names be the same for the first two images like the forth one? for some other part files i have those 3 the same but for this part (which was generated via content center and re-named) they are different. I've played with different names and it seems like it just hides the extension on one of them for this file. (and its the opposite for the 3rd image)
I need this for the attached ilogic code which says it can't find the file although file-occurance-display-browser (don't know if there are any other!) names are the same
thx in advance
Dim openDoc As Document
openDoc = ThisDoc.Document
i = New integer(){1,2,3}
j = New integer(){1,2,3}
Dim docFile As Document
i=1001
j=10
If openDoc.DocumentType = 12291 Then
	For Each docFile In openDoc.AllReferencedDocuments
	If  docFile.ComponentDefinition.BOMStructure = 51970 Then
		If docFile.DocumentType = 12290  Then
			iProperties.Value(docFile.DisplayName, "Project", "Project") = Project
			iProperties.Value(docFile.DisplayName, "Project", "Part Number") = Project_Code+CStr(Group_Code)+"."+Right(CStr(i),3)
			i=i+1
		End If
		If docFile.DocumentType = 12291 Then
			iProperties.Value(docFile.DisplayName, "Project", "Part Number") = Project_Code+CStr(Group_Code+j)
			j=j+1
		End If
	End If
	Next
End If
Olgan
and here is the 4th image
