disabling Error/Warning prompts
davidt162003
davidt162003
Is their a way to disable the prompts such as file not saved to current project or design representation locked? and in general is it a good idea to disable these?
HII
FINET_Laurent
Hello @davidt162003,
Here find the line of code that disable such pop up messages :
ThisApplication.SilentOperation = True
If you ask my opinion, it is usually set back to false later in the same code, and should be handled carefully with the exeptions. Otherwise the operator might miss important messages. Error / warning / info messages are there for a good reason.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
davidt162003
silent operation inst quite what im looking for i think as it seems to suppress more than just pop ups if memory serves right. TBH im also of the opinion they should be left as is
HII
Jacob__with__a__k
You can disable certain prompts at File-->Options (Application Options)-->Prompts
no clue how to disable the promps that are not listed here
Ilogic specific promps are usally not a good idea to disable
Happy coding!
WCrihfield
Hi @davidt162003.  Just so you area aware, there is an application level setting, as @FINET_Laurent pointed out, but there is also a couple other settings by the same name, for the same functionality in other places with narrower scope of control.  There is an iLogic only setting, like the following:
iLogicVb.Automation.SilentOperation
Then there is a per iLogic rule scope setting, that is actually a property of the individual iLogic rule itself.  That setting can be set manually in the Options tab of the iLogic rule editor while editing a specific iLogic rule, or it can be set by code for that one specific rule.
iLogicVb.Automation.GetRule(ThisDoc.Document, iLogicVb.RuleName).SilentOperation = True
Wesley Crihfield
(Not an Autodesk Employee)
