Disable update of idw properties from ipt
LucapTdm
LucapTdm
Hi all,
is there a way, with iLogic, to disable the copy of model iProperties directly into the drawing?
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @LucapTdm,
Unfortunately no, since there is no API exposed to toggle the "Copy Model Properties" option.
As a workaround though, if you are looking to set any property values using the API, do take a look at the below article:
http://adndevblog.typepad.com/manufacturing/2013/12/copy-iproperties-of-model-document-to-drawing-do...
Sajith
Sajith Subramanian
Autodesk Developer Network
LucapTdm
Thanks for your help, but what I am trying to accomplish is actually to prevent Inventor from updating automatically some properties (revision number in this case) since I've a custom iLogic rule to do that when saving the idw file.
I will dig into my rule to find a workaround.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @LucapTdm,
If you are updating some properties through iLogic means, It will override the existing property values which are updated automatically.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
