I will give you an example which can be tested in ilogic,but I won't explain for it.
AddReference "System.Drawing"
AddReference "System.Windows.Forms"
Imports System.Windows.Forms
Class ThisRule
Sub main
Dim wrapper = New HwndWrapper(ThisApplication.MainFrameHWND)
Dim dialog As New dialog1
dialog.Show(wrapper)
End Sub
End Class
Public Class dialog1
#Region "Designer generated"
Inherits System.Windows.Forms.Form
Public Sub New()
InitializeComponent()
End Sub
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
Private components As System.ComponentModel.IContainer
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
Me.TableLayoutPanel1 = New System.Windows.Forms.TableLayoutPanel()
Me.OK_Button = New System.Windows.Forms.Button()
Me.Cancel_Button = New System.Windows.Forms.Button()
Me.DataGridView1 = New System.Windows.Forms.DataGridView()
Me.Column1 = New System.Windows.Forms.DataGridViewTextBoxColumn()
Me.Column2 = New System.Windows.Forms.DataGridViewTextBoxColumn()
Me.Column3 = New System.Windows.Forms.DataGridViewTextBoxColumn()
Me.TableLayoutPanel1.SuspendLayout()
Me.SuspendLayout()
'TableLayoutPanel1
Me.TableLayoutPanel1.Anchor = CType((System.Windows.Forms.AnchorStyles.Bottom Or System.Windows.Forms.AnchorStyles.Right), System.Windows.Forms.AnchorStyles)
Me.TableLayoutPanel1.ColumnCount = 2
Me.TableLayoutPanel1.ColumnStyles.Add(New System.Windows.Forms.ColumnStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Controls.Add(Me.OK_Button, 0, 0)
Me.TableLayoutPanel1.Controls.Add(Me.Cancel_Button, 1, 0)
Me.TableLayoutPanel1.Location = New System.Drawing.Point(746, 245)
Me.TableLayoutPanel1.Name = "TableLayoutPanel1"
Me.TableLayoutPanel1.RowCount = 1
Me.TableLayoutPanel1.RowStyles.Add(New System.Windows.Forms.RowStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Size = New System.Drawing.Size(146, 27)
Me.TableLayoutPanel1.TabIndex = 0
'OK_Button
Me.OK_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.OK_Button.Location = New System.Drawing.Point(3, 3)
Me.OK_Button.Name = "OK_Button"
Me.OK_Button.Size = New System.Drawing.Size(67, 21)
Me.OK_Button.TabIndex = 0
Me.OK_Button.Text = "Apply"
'Cancel_Button
Me.Cancel_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.Cancel_Button.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Cancel_Button.Location = New System.Drawing.Point(76, 3)
Me.Cancel_Button.Name = "Cancel_Button"
Me.Cancel_Button.Size = New System.Drawing.Size(67, 21)
Me.Cancel_Button.TabIndex = 1
Me.Cancel_Button.Text = "Cancel"
Me.DataGridView1.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize
Me.DataGridView1.Columns.AddRange(New System.Windows.Forms.DataGridViewColumn() {Me.Column1, Me.Column2, Me.Column3})
Me.DataGridView1.Location = New System.Drawing.Point(62, 34)
Me.DataGridView1.Name = "DataGridView1"
Me.DataGridView1.RowTemplate.Height = 23
Me.DataGridView1.Size = New System.Drawing.Size(353, 59)
Me.DataGridView1.TabIndex = 1
'Column1
Me.Column1.HeaderText = "Column1"
Me.Column1.Name = "Column1"
'Column2
Me.Column2.HeaderText = "Column2"
Me.Column2.Name = "Column2"
'Column3
Me.Column3.HeaderText = "Column3"
Me.Column3.Name = "Column3"
Me.AcceptButton = Me.OK_Button
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 12.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
Me.CancelButton = Me.Cancel_Button
Me.ClientSize = New System.Drawing.Size(904, 283)
Me.Controls.Add(Me.TableLayoutPanel1)
Me.Controls.Add(Me.DataGridView1)
Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
Me.MaximizeBox = False
Me.MinimizeBox = False
Me.Name = "dialog1"
Me.ShowInTaskbar = False
Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
Me.Text = "dialog1"
Me.TableLayoutPanel1.ResumeLayout(False)
Me.ResumeLayout(False)
End Sub
Friend WithEvents TableLayoutPanel1 As System.Windows.Forms.TableLayoutPanel
Friend WithEvents OK_Button As System.Windows.Forms.Button
Friend WithEvents Cancel_Button As System.Windows.Forms.Button
Friend WithEvents DataGridView1 As System.Windows.Forms.DataGridView
Friend WithEvents Column1 As System.Windows.Forms.DataGridViewTextBoxColumn
Friend WithEvents Column2 As System.Windows.Forms.DataGridViewTextBoxColumn
Friend WithEvents Column3 As System.Windows.Forms.DataGridViewTextBoxColumn
#End Region
Private Sub OK_Button_Click(sender As System.Object,e As System.EventArgs) Handles OK_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Me.Close()
End Sub
Private Sub Cancel_Button_Click(sender As System.Object,e As System.EventArgs) Handles Cancel_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Close()
End Sub
End Class
Class HwndWrapper
Implements IWin32Window
Private ReadOnly m_hWnd As IntPtr
Public Sub New(ByVal hWnd As IntPtr)
m_hWnd = hWnd
End Sub
Public Sub New(ByVal hWnd As Integer)
m_hWnd = CType(hWnd, IntPtr)
End Sub
Public ReadOnly Property Handle As IntPtr Implements IWin32Window.Handle
Get
Return m_hWnd
End Get
End Property
End Class
