Disable radial marking menu control
rogmitch
rogmitch
Does anyone know if I can mimic Inventor and disable (grey out) radial menu controls when not applicable?  It is for an addin using VB.Net
Any help much appreciated.
Roger Mitchell
IV 2014 Prof SP1, VS 2013
xiaodong_liang
Autodesk Support
Autodesk Support
have you tried to get the control and call ControlDefinition.Enabled = false?
rogmitch
Hi Xiaodong,
Thank you.  Your suggestion solved the problem. I very much appreciate the response,
Roger
