disable parameters when part is supressed... or?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All
I have a configurator assy, which is controlled with an iLogic rule.
one of the parts is being changed in a lot of ways according to the different configurations. But in one of the Configurations the part must be supressed, which works fine, however next time i run the rule i get an error message from all the other instances where it would change a parameter if the part was active.
I have tried adding if [the configuration that makes the part supressed] = False then, in the beginning of the the code that fails, to simply prevent it from running, but it still makes an error.
and as you can see i have a lot of lines where the part normally would be configurated..
Error on Line 628 : Method arguments must be enclosed in parentheses.
Error on Line 629 : Method arguments must be enclosed in parentheses.
Error on Line 633 : Method arguments must be enclosed in parentheses.
Error on Line 634 : Method arguments must be enclosed in parentheses.
Error on Line 637 : Method arguments must be enclosed in parentheses.
Error on Line 642 : Method arguments must be enclosed in parentheses.
Error on Line 643 : Method arguments must be enclosed in parentheses.
Error on Line 646 : Method arguments must be enclosed in parentheses.
Error on Line 647 : Method arguments must be enclosed in parentheses.
Error on Line 649 : Method arguments must be enclosed in parentheses.
Error on Line 654 : Method arguments must be enclosed in parentheses.
Error on Line 656 : Method arguments must be enclosed in parentheses.
Error on Line 673 : Method arguments must be enclosed in parentheses.
Error on Line 678 : Method arguments must be enclosed in parentheses.
Error on Line 679 : Method arguments must be enclosed in parentheses.
Error on Line 682 : Method arguments must be enclosed in parentheses.
Error on Line 683 : Method arguments must be enclosed in parentheses.
Error on Line 686 : Method arguments must be enclosed in parentheses.
Error on Line 687 : Method arguments must be enclosed in parentheses.
Error on Line 690 : Method arguments must be enclosed in parentheses.
Error on Line 691 : Method arguments must be enclosed in parentheses.
Error on Line 694 : Method arguments must be enclosed in parentheses.
Error on Line 695 : Method arguments must be enclosed in parentheses.
Error on Line 698 : Method arguments must be enclosed in parentheses.
Error on Line 699 : Method arguments must be enclosed in parentheses.
Error on Line 702 : Method arguments must be enclosed in parentheses.
Error on Line 703 : Method arguments must be enclosed in parentheses.
Error on Line 709 : Method arguments must be enclosed in parentheses.
Error on Line 714 : Method arguments must be enclosed in parentheses.
Error on Line 724 : Method arguments must be enclosed in parentheses.
Error on Line 729 : Method arguments must be enclosed in parentheses.
Error on Line 739 : Method arguments must be enclosed in parentheses.
Error on Line 744 : Method arguments must be enclosed in parentheses.
Error on Line 754 : Method arguments must be enclosed in parentheses.
Error on Line 759 : Method arguments must be enclosed in parentheses.
Error on Line 776 : Method arguments must be enclosed in parentheses.
Error on Line 777 : Method arguments must be enclosed in parentheses.
Error on Line 780 : Method arguments must be enclosed in parentheses.
Error on Line 781 : Method arguments must be enclosed in parentheses.
Error on Line 784 : Method arguments must be enclosed in parentheses.
Error on Line 785 : Method arguments must be enclosed in parentheses.
Error on Line 788 : Method arguments must be enclosed in parentheses.
Error on Line 789 : Method arguments must be enclosed in parentheses.
Error on Line 792 : Method arguments must be enclosed in parentheses.
Error on Line 793 : Method arguments must be enclosed in parentheses.
Error on Line 796 : Method arguments must be enclosed in parentheses.
Error on Line 797 : Method arguments must be enclosed in parentheses.
Error on Line 877 : Method arguments must be enclosed in parentheses.
Error on Line 878 : Method arguments must be enclosed in parentheses.
Error on Line 943 : Method arguments must be enclosed in parentheses.
Error on Line 944 : Method arguments must be enclosed in parentheses.
Error on Line 947 : Method arguments must be enclosed in parentheses.
Error on Line 948 : Method arguments must be enclosed in parentheses.
Error on Line 953 : Method arguments must be enclosed in parentheses.
Error on Line 954 : Method arguments must be enclosed in parentheses.
Error on Line 957 : Method arguments must be enclosed in parentheses.
Error on Line 958 : Method arguments must be enclosed in parentheses.
Error on Line 964 : Method arguments must be enclosed in parentheses.
Error on Line 965 : Method arguments must be enclosed in parentheses.
Error on Line 968 : Method arguments must be enclosed in parentheses.
Error on Line 969 : Method arguments must be enclosed in parentheses.
Error on Line 974 : Method arguments must be enclosed in parentheses.
Error on Line 975 : Method arguments must be enclosed in parentheses.
Error on Line 978 : Method arguments must be enclosed in parentheses.
Error on Line 979 : Method arguments must be enclosed in parentheses.
Error on Line 982 : Method arguments must be enclosed in parentheses.
Error on Line 983 : Method arguments must be enclosed in parentheses.
Error on Line 986 : Method arguments must be enclosed in parentheses.
Error on Line 987 : Method arguments must be enclosed in parentheses.
Error on Line 990 : Method arguments must be enclosed in parentheses.
Error on Line 991 : Method arguments must be enclosed in parentheses.
Error on Line 997 : Method arguments must be enclosed in parentheses.
Error on Line 998 : Method arguments must be enclosed in parentheses.
Error on Line 1001 : Method arguments must be enclosed in parentheses.
Error on Line 1002 : Method arguments must be enclosed in parentheses.
Error on Line 1005 : Method arguments must be enclosed in parentheses.
Error on Line 1006 : Method arguments must be enclosed in parentheses.
Error on Line 1009 : Method arguments must be enclosed in parentheses.
Error on Line 1010 : Method arguments must be enclosed in parentheses.
Error on Line 1013 : Method arguments must be enclosed in parentheses.
Error on Line 1014 : Method arguments must be enclosed in parentheses.
Error on Line 1019 : Method arguments must be enclosed in parentheses.
Error on Line 1020 : Method arguments must be enclosed in parentheses.
Error on Line 1022 : Method arguments must be enclosed in parentheses.
Error on Line 1023 : Method arguments must be enclosed in parentheses.
Error on Line 1028 : Method arguments must be enclosed in parentheses.
Error on Line 1029 : Method arguments must be enclosed in parentheses.
Error on Line 1031 : Method arguments must be enclosed in parentheses.
Error on Line 1032 : Method arguments must be enclosed in parentheses.
Error on Line 1039 : Method arguments must be enclosed in parentheses.
Error on Line 1040 : Method arguments must be enclosed in parentheses.
Error on Line 1042 : Method arguments must be enclosed in parentheses.
Error on Line 1043 : Method arguments must be enclosed in parentheses.
Error on Line 1050 : Method arguments must be enclosed in parentheses.
Error on Line 1051 : Method arguments must be enclosed in parentheses.
Error on Line 1053 : Method arguments must be enclosed in parentheses.
Error on Line 1054 : Method arguments must be enclosed in parentheses.
Error on Line 1059 : Method arguments must be enclosed in parentheses.
Error on Line 1060 : Method arguments must be enclosed in parentheses.
Error on Line 1062 : Method arguments must be enclosed in parentheses.
Error on Line 1063 : Method arguments must be enclosed in parentheses.
Error on Line 0 : Maximum number of errors has been exceeded.
I don't understand how to enclose the argument in parentheses..
hope some knows a trick to bypass/Disable these lines...
/LSA-Skan
