Disable Form Resizing in iLogic
danijel.radenkovic
danijel.radenkovic
Hello to all,
Is it possible to disable form resizing in iLogic?
Many thanks!
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
richard.joseph.pollak
I do not know how to do this with local forms, but I was able to do this with a global form.
Where RuleName is the name of your rule, look for this file:
\Design Data\iLogic\UI\RuleName.state.xml
Set the size of the form how you want it locked and then close it. Next, set the *.xml file you looked for to 'Read Only'.
The users can resize the form while using it, but it will always open the way you set it. This was sufficient for my purposes. It would be nice to know how to permanently lock the size though.
danijel.radenkovic
Hello Sir,
Thank you very much for the reply.
Yes, this is possible if you work with Gobal Forms cause they have "Containing Folder" with path "C:\Users\Public\Documents\Autodesk\Inventor 201x\Design Data\iLogic\UI" but this is not the case with Local Forms.
I will continue with searching for the solution.
Best regards
Danijel
