Direct Edit Part / Face with iLogic
C_Haines_ENG
Message 1 of 9
C_Haines_ENG
Hello all,
Is it possible to direct edit solid bodies through iLogic API? I've seen very few posts about it and Inventor doesn't seem to show anything for it so I'd like to know if this is possible.
I would select a face, and it would direct edit it -4mm.
Thanks!
Replies (8)
Message 2 of 9
J_Pfeifer_
Message 3 of 9
C_Haines_ENG
Guess my google-fu was off today. Thanks!
Message 4 of 9
C_Haines_ENG
Actually these only get already placed direct edits dont they? I want to CREATE a direct edit.
Message 5 of 9
J_Pfeifer_
I was just linking to the references on the documentation. Figured it would be somewhere in one of these items. From my understanding it would have had a .Create Definition portion.
Looking at the objects again you cannot use these to create anything due to their read only nature. Due to faces and features not exposing a direct edit method I have no idea how you would create the direct edit to start. Seems you can only use the direct edit objects to gain information from the model. Not modify it, or create it.
Someone else might know but other than these items, I see no way to interface with a direct edit in the documentation.
Message 6 of 9
C_Haines_ENG
I was able to figure it out, the Inventor API website absolutely sucks.
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oFaceProxy As FaceProxy = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Pick a feature")
Dim oFaces As FaceCollection = ThisApplication.TransientObjects.CreateFaceCollection
Dim oDoc As PartDocument = ThisApplication.Documents.Open(oFaceProxy.Parent.Parent.ReferencedDocumentDescriptor.FullDocumentName, False)
oFaces.Add(oFaceProxy.NativeObject)
Dim oDocFeat As PartFeatures = oDoc.ComponentDefinition.Features
Dim oMoveDef As MoveFaceDefinition = oDocFeat.MoveFaceFeatures.CreateDefinition(oFaces)
oMoveDef.SetDirectionAndDistanceMoveType("4 mm" , oFaces.Item(1), True)
Dim oMoveFeat As MoveFaceFeature = oDocFeat.MoveFaceFeatures.Add(oMoveDef)
oDoc.Save : oDoc.Close
Message 7 of 9
J_Pfeifer_
Is this actually creating an object within the Direct edit collection?
It seems that we can access the count of the items within that direct edit. My concern or thought is that the move face feature is not actually a direct edit? Just seems like we would get to these features through the collection of direct edits, not the edits themselves to have multiple definitions.  Either way glad it worked for you.
I second your opinion of the documentation entirely. Half of us come here to the forums for things that should be a single page.
Message 8 of 9
C_Haines_ENG
In my attempts to get this working, it doesn't actually look like direct edit is a command you can put into a script. I believe its actually just an assortment of other tools such as MoveFaceFeatures and MoveFeatures, and direct edit is just a collection of those operations.
Therefore the DirectEdit documentation can only be used to access items created by the user. Absolutely terrible! 🙂
Also now I have to figure out how to find if the face I'm clicking has already had a face moved. I'm sure going to enjoy that as well.
Message 9 of 9
C_Haines_ENG
Try
	Dim oCheckMoved As MoveFaceFeature = oFaceProxy.NativeObject.CreatedByFeature
	MsgBox("FACE IS ALREADY MOVED")
	Exit Sub
Catch
End Try
