Direct Edit and API
Direct Edit and API
DavidTruyens
Direct Edit and API
DavidTruyens
Dear all,
I would like to use the scale function of direct edit using the API. Now the good news is that I found out that it's possible from 2016. But it's hard to find any documentation on Direct Edit and the API. Does anyone as a small example?
Thanks a lot in advance,
David
David Truyens
Technical Specialist
Twitter | LinkedIn | IDCM | GitHub
mikazakov
David,
DirectEditFeatures not have Add-method unfortunately.
Maximum you call command programmatically:
Call ThisApplication.CommandManager.ControlDefinitions("PartNGxDirectEditCtxCmd").Execute
DavidTruyens
Hi Mikazakov,
Thanks for your reaction. Its a pity that that doesn't work. Do you have another idea to do a non-uniform scaling on a body? It may as well be on transient geometry.
Thanks for your reaction!
David Truyens
mikazakov
May be use:
PartFeatures.NonParametricBaseFeatures
but I have not looked in detail
DavidTruyens
Hi Mikazakov,
I've been trying that, but no option for scaling as far as I can see. But I've found a work around. In the end I just need a box. It would be nice to start with the exising box, but I'll create one from scratch.
Thanks for you suggestions!
David
David Truyens
